ok, i had soft brake pedal. i bled all four starting from the right rear and worked my way closer to the master cylinder. all went well. or so i thought. still had a soft pedal. so, i replaced the master cylinder. i bench bled the M/C and then rebled the lines. still a soft pedal. the front calipers looked questionable, so i just replaced those today. bled the whole system. again. still a soft pedal!! WTF?? what else can i check here? could the booster be shot? there aren't any brake lines broken, i know that for sure. could the ABS module be the culprit? i'll figure out how to bypass that POS if i can. i've been fighting this brake issue for a month and i still can't drive my truck. short of a match, i'm at a loss.
