Squealing noise!
Z71tahoe09
Hi everyone. I have a 2009 z71 Tahoe. It has about 141,000 miles on it. Recently I've noticed a squealing noise while driving at a low speed. It's worse when I turn corners and it happens while I'm decelerating also. Any ideas or advice?
Ont240
Possible wheel bearing. Jack up the front end so both wheels are off the ground. Saftey stands are a good idea. Rotate each wheel to see if it spins without being notchy. Grab the tire top and bottom, and try rock it in and out. There should be absolutely no play.
