ayeplussjr
- Jan 31, 2008
Hey guys....about 5000 miles ago I was hearing some sort of squeaking noise coming from the drive belt area, and this only happened when I started the engine in the morning or if it has been sitting there for a couple of hours. I took it to the shop and they replaced the serpentine belt, problem solved at that time. Now, I've been hearing that same noise again when I start up the engine in the morning or after about 4 hours of driving the car. Once I drive off I can hear the squeaking a little bit in the morning, but goes away a few minutes later
Usually in the middle of the day it goes away with no squeaking. Only happens usually in the morning when I take off for work, or if the car has been sitting there for about 4 hours, and I start it up again.
Any suggestions? The serpentine belt is still in good shape, can it possibly be the second belt for the air conditioning?
