I just got a 2001 tahoe, it has an automatic and the push button 2wd/4wd drive with the auto 4wd drive option. The truck has just under 150,000. Recently, when accelerating, it has started to squeak and squeal which then changes to a rattle and grind noise as soon as you back off of the accel. the noise stops. Sometimes it stops on its own and sometimes we have had to stop and shift through all the gear and then it seems to be fine. It only acts this way occasionally but seems like it might be happening more often. Someone once said that it was something to do with the 4wd, but I'm really not sure. Any ideas would be appreciated. Is this something that can be checked using a code reader? Thanks, I'm new to tahoe ownership
