See:
http://www.tahoeforum.com/showthread.php?t=11641
I took it to a shop, had the rear brakes replaced, which I was told would probably stop the sound. While the brakes were indeed TERRIBLE (shoes in the rear were worn to the rivets) the sound did not stop. Talked to the owner of the shop that replaced my shoes, drums, and fixed the front diff leak and he said he had a 99 Tahoe that made the same sound (only less pronounced).
He said barring a complete clean external inspection (bearings, rods, bushings, etc) he could almost guarantee 99% that it was something to do with the spider gears in the differential, and if left to its devices for too long, could result in a bad differential.
What are your thoughts on this?
