HitandRunDriver
Finally got my set of NGK Iridium plugs today, picked up the haynes repair manual and started reading.
I have an 01 tahoe LT with the 5.3 and heres what I've understood so far.
The OEM gap of the plugs is set at .060
I should use an anti seize lube on the threads
The spark plug wiring is ok, even after 100k unless I notice damage to them
Anyway, i think Boostaholic had mentioned that he had his plugs set at .035 for increased power. On the 04-06 the plug gap is .040. How short can i realistically gap my plugs if i want to see any type of gain without drastically shortening the life of the plugs? Also, does anyone have a recommended anti seize lube or can i basically use whatever I find at autozone.
