sandrock
Yeah, it's gonna be one of THOSE posts...
Patient: 99 Tahoe LT, 230k on the ticker.
Symptom 1: Auto 4wd does not engage. 2hi, 4hi and 4low work as they should.
Symptom 2: 4hi lamp on switch stays lit regardless of whatever mode is selected. If 2hi is selected, 2hi is lit, 4hi remains lit, and so on. If I select 4hi, it dims a little but remains on. Disassembled switch, reflowed all solder points (and added LEDs for backlighting along with limit resistor), same result. New switch, same result.
I have a 100.00 deductable powertrain warranty that I got when I bought the truck, so if it's the transfer case I'm covered. Anything electrical like the actuators and encoders I'm on my own, so I need to know if anyone else has had issues like this, or even what I can rule out.
Thanks guys!
Thanks guys!
