should i leave my air dam on?
99chevytahoe
IL
I have a stock 99 tahoe 4wd at stock height. I hit a pretty big pothole wich broke my air dam on both sides by the tires. I didn't feel like looking at a half broken airdam so i took it off and i had to take it off in such a way that i will have to replace it if i decide to because the mounting brackets are snapped off. I did some reading and saw sone things about how the air dam helps handling and engine temp but all i want to know is:
Will having the air dam off screw with my mpg that much?
Will it effect engine cooling and handling on said tahoe?
I could care less about how it looks with or without it i just dont any long term affects.
Definitely, if gonna spend the money ought to get something cool.....
99chevytahoe
IL
Im thinking i could just cut out holes for fogs..
The only problem is the plastic around where the bolts screw into the air dam is broke and still attatched to the bolts. How can i reattach that plastic to the air dam and then
to the bumper?
80 bucks is alot for a air dam
Get some plastic welding rods and a large (higher wattage) soldering iron with a chisel point.....
