Shocks.
Jesters.
It's time for me to replace my Shocks. Mine are so done that if I drive over a pebble, it'll squeek.
I was looking at a couple on 4wheelparts.com. What are your guys opinions on these?
Pro Comp ES1000 Shocks
http://www.4wheelparts.com/Lift-Kit...hocks.aspx?t_c=1&t_s=90&t_pt=100423&t_pl=5409
Pro Comp ES3000 Shocks - Set of 4 Shocks
http://www.4wheelparts.com/Lift-Kit...hocks.aspx?t_c=1&t_s=90&t_pt=100423&t_pl=5410
Pro Comp ES9000 Shocks
http://www.4wheelparts.com/Lift-Kit...hocks.aspx?t_c=1&t_s=90&t_pt=100423&t_pl=5411
What is the main difference between each Shock though? Sorry I never work with Shocks so I don't know jack about them.
jneal
Sandy Springs Ga
I will say that the 3000's are the stiffest shocks I've ever had. Took them off my jeep they were so bad.
just FYI.
Jesters.
Hm okay, what should I look into? I'm looking for any suggestions.
Bilstein 5100s, bilstein HDs, rancho rs9000XLs, etc. I'd drop dime on the nicer ones, you'll thank yourself later.
spleuba
Gents: My 2004 Tahoe 4wd LT has 78,000 miles. I just purchased a complete set of Bilstein HD shocks. The truck is not lowered. What else should I replace when doing the shocks? Are there particular bushings or or other components that usually go about now? Thanks.
-Sean
