adam74
have a 95 tahoe 4x4 with the 4L60 auto trans and 265/70/17 tires. was wondering if there was a way to adjust the shift points. I ask because it seems to not want to stay in od when going up slight inclines much less hills and will downshift with a very light pedal. seems like it should stay in od for longer than what it is doing. driving around town its not quite as bad and I get 11 mpg but went to deer lease last weekend which is a 3 hour trip and only got 10.5 mpg. truck is rated for close to 15 highway. it does seem to run rich which I believe is due to a 180 deg thermostat installed by previous owner. going to install a stock 195 degree tomorrow. have replaced plugs, wires, cap and rotor, egr valve and selenoid, iac, fixed vacuum leaks, new o2 sensor, new cat (which made it pass emissions finally lol). I know the trans for the most part is electronically controlled but would adjusting the tv cable possibly help? dont know if its out of adjustment or not but did read somewhere it controls shift points and not really sure how to adjust it. any info is appreciated. thanks guys
