Several Problems
albinoturtles
any help appreciated -
I ran auto zone computer to diagnose and got:
c0299 but not much info I can find..... - I did a vacuum leak test and all 3 tests passed, so no leak i am assuming.
I see that it is a brake booster solenoid code is that different then a leak?
StabilitraK, Brake light, and check brake system lights are on, and stay on. I have changed brakes 2-3 times, rotors once , and everything seemed fine for a few weeks but then they start grinding again. fluid is between max and min.
I got P0449 - but supposedly thats just the gas cap?
also got P0573 for the cruise control that never works....
and I got a P1258 which I attributed to a broken heater hose that mechanic hit while checking fluids, and I replaced the connection...so far that one is taken care of unless someone knows its something else?
ANY HELP on the c0299 WOULD BE greatly appreciated....
