Seafoam and water question....
ac1975
Denver, CO
So I seafoamed the 'hoe tonight. Really didn't smoke much at all....
Anyways, at first, I was going to use a plastic water bottle. I was pretty sure it was 100% dry, but when I poured the 1/3 of seafoam, I noticed what might be little water bubbles floating in there. I ended up pouring from the seafoam can into the intake. I'm not sure about what to do with the seafoam in the water bottle. Can I still pour that into the gas tank? It is a water remover right? When I last checked the water bottle, you couldn't really see the water anymore...
ac1975
Denver, CO
Hmm.. just did some googling and read that seafoam has some water in it, and also that the IPA (or whatever you call it) actually helps the water to blend with petro.
