Replacement Light Bulbs for Controls
anorac
I have several lights burnt out in my dash, the ones behind the rear wiper and fog light control and the ones behind the headlight controls.
I have taken the assembly apart and see that they are soldered in, now my only problem is finding out what type of bulb I need for this application and what wattage it needs to be ?
Is there a LED light that I can use to replace the stock bulb ?
NJTahoe
Central New Jersey
I have the same problem. If you find anything out let me know also. I would like to replace those bulbs also one weekend
hoss81
I also have this problem with mine. I believe that the instrument clusters use a type #74 bulb. I'm still researching this but so far according to the dimensions, that's the only one that makes sense.
Silverado777
Anything 02 and older should have mostly twist in bulbs, anything 2003 and newer will have solder in bulbs.
