Remote Key Entry does not work
troy52
I have a 2007 Tahoe LTZ, both RKE that came with it do not work. I have changed the batteries, tried the relearn process several times and still a no go. Does anyone know what else the problem could be and how to fix it?
llllljrlllll
When you did the relearn process, did it go to active learning? If it didn't, then your answer is your dsm fuse needs to be reset. The fuse is located on the driver side, on the dashboard, just open the door and you'll see the panel there. Look on your tahoe manual, and it'll tell you exactly where it is, pull it out, wait 20 seconds, put it back in, and now you should be able to make it work. Good luck.
