Yeah, I did this a few months back. I think there is a write up on this, you might want to try a search on it. Here is what I remember. If you take the side cover off of the driver side seat, you will see a long threaded bolt with a brass ring around it. The brass ring is what stops the seat from fully reclining. I took a dremel with a cutting disk on and cut the ring in two places. I then took a flat headed screw diver and pryed the pieces off. Be careful not to damage the threads on the rod. After that, my driver seat fully reclines. I did not do the passenger side, because I wasn't concern about it. Hope this helps, if not I will try to steer you in the right direction.
