Tis the season, I finally spent a few dollars on myself to fix up a couple of little items on my 2002 Yukon XL. Now all is sweet except the rear wiper. Still can't figure that out.
Problem. Does not work. When you turn it on, you can hear the motor 'trying' to do something. Tried to help by manually moving it, but no help. I assumed it was the motor.
I replaced the motor yesterday and is still does the same thing. The only exception....with a 'helping hand' I can get it to actuate VERY slowly for one pass.
Is there a relay or something that I am missing? With the new motor, I did remove the wiper arm and ran the motor just to see if ther was too much tension on the arm. It didn't help. The same thing. It just seems that the power getting to it is very weak.
Also, not sure if this is related. But I can't get the rear or mirror defrosts to work. The light on the control turns on, but does not defrost. I have checked the fuses and changed the rear defrost relay in the fuse center under the hood.
Any suggests are welcome. Sorry for the long post. Thanks for the help!!!
