Gm recommends replacing glass
pop5948 - Had the same thing happen to my 07 LT2. GM recommends replacing the glass. Problem is, if you try using a conducting epoxy you have to use a high temp solder gun and have a 50/50 chance of breaking the glass. My body shop guy had his glass man replace it. Ended up replacing it twice after the left wire fell off the first replacement glass.
