Rear turn signal and reverse light acting nuts
powellent
While the break is applied the turn light goes dim and reverse light comes on. On passenger side only
rockenthebowtie
Any time I want
Most likely a bad rear lamp junction block its mounted behind the right side quarter at the rear toward the rear bumper you will see that tail lamp connetors plugged into to it
powellent
please help
I cant find the block.
Traced it to the harness above spare tire and goes into the loom
I unplugged the short harness the lights plug into and it worked for a little while?
rockenthebowtie
Any time I want
Looks like vehicles with rpo Z75 - E52 have that circuit board. .. but anyway since you said you disconnected the connector and reconnected disconnect that same connector and with a pair of needled nose pliers slightly twist the male terminal connectors so that it assures a good connection also see if you can trace the black wire to it's ground location and make sure thatsnice and tight if none of that works you may need to replace the tail lamp harness assy for that side unfortunately I think you may have to purchase the hole tail lamp assy from the dealer so you may need to see if one is available online
