I had a 1999 Tahoe with 410,000 kilometres that never made a sound. The 1999 Yukon I now have had 100,000 Kilometres and the clunk when I got it. I greased mine and 20,000kilometres later it is fine. I used a high temperature lithimum grease.
You asked about other maintenance items. Get comforatable with adjusting the rear brakes. Everyone complains about the brakes on these things and they are right, however, if you service and adjust the rear brakes a couple of times per year they are fine.
Fuel pumps are another issue. If you change fuel filters on schedule, you can extent the life of your pump, however, if you keep your hoe you will do a pump (or two). It is an easy job if you know how and can be done in the backyard in a couple of hours.
There are issues with the ignition, heater A/C switches on some vehicles, others vehciles are problem free. There are issues with hard steering at slow speeds on some vehicles, others never experience any problems.
Remember, your hoe is 12 years old and like any vehicle age does not improve them. They need maintenance and I've found it is better to do preventive maintenance than it is to be towed home. According to my wife I'm kind of anal, if I hear smell or see something, I fix it before it leaves me on the side of the road.
