rear seat latch stuck after tightening seat down
99chevytahoe
IL
So after replacing carpet I started to throw my seats back in. It was kinda frustrating because I replaced the old carpet padding with 1/2 padding and doubled up on the exhaust side.. so my bolts didnt want to go in at first.
This brings me to my problem the rear seats especially gave me a hard time with the bolts and when I finally tighten them down the release lever for the seat gets stuck and I need an enormous amount of force the pull the tab.
I suspect I made the mistake of doubling up in spots because thatsone inch verses maybe a half inch for where the factory doubled up. Im gonna remove a layer and see if that works can someone tell me if my hunch is right?
99chevytahoe
IL
Taken the padding out barely helps.. after I get the 3 bolts and the torx one all tightened it still is not wanting to open.. I need help!!
Unbolt it one bolt at a time to see if it helps, does it work ok? If so the seat may be twisting..... You can shim it with some thicker washers.....
99chevytahoe
IL
Yeah its fine now i suspect my sub may have vibrated the seat into its natural position... lol. Its not really thats bad anymore. Thanks
