black dog your right!!, it has leaf springs, no panhard bar. I did some major measuring under there, (back of brake drums to frame and both sides are the same, so the axle is sitting true to the frame) no body damage either. the best I can tell by measuring the body to the frame, is the whole body is mounted on the frame more to the drivers side than the passenger side, they had to have done this at the factory.
now having said that, how hard would it be to loosen the body to frame bolts and shift the body over to where it should be? I figure it has to move to the passengers side about 1/2 of an inch. my tire to fenderwell measurement on the drivers side is out about 1", so if I move the body over 1/2" , I'll gain a 1/2" on the passenger side, and lose 1/2" on drivers side. the best I can figure. does that make any sense to you? I have a feeling moving the body over isn't as easy as it might sound, right?
