Questions - 07 Tahoe LT
AAHTahoe
Tempe, AZ
I received a free The Club device. I can not find it on the Internet - it's like a regular Club but there are two hooks at each end instead of the customary one hook. Anyone seen any of these and or use it?
Also, I've found the source of the vibration when music with heavy bass plays thru the stock sound system in my LT. The lock tab on the driver side front door is loose enough that it will rattle no matter whether the door is locked (In the down position.) or unlocked. The rattle stops if I put my finger on it when it is locked or hold it between my fingers when the door is unlocked. Anyone else have this problem and short of going to the dealer, is there an easy way to deal with this rattle.
TIA ... Allen
73shark
KC, MO area
As far as using the club, no I don't use one as they can be defeated any way, I rely on the Ostar service.
Yep, they just take a large bolt cutter and cut the steering wheel rim and slip the club off. There used to be (maybe still is) something called Pedallock the goes between the brake pedal and floorboard and locks. Can still be cut out but takes a little longer. If they want your truck, it's gone. :ack:
