After being on hold w/ Edelbrock/Russel Technical Support for half my morning, I'm turning to you all for help. I also want to confess that I have only a tiny amount of the knowledge, wisdom, and experience contained by most of you on this site. Operating under the "there's no such thing as a stupid question" premise, here is my question ...
I am going to install the Russell Brake Line kit on my '01 Tahoe 4WD and have a very basic question. How do I avoid brake fluid pouring out of the line when I disconnect the current rubber line, and thereby draining the master cylinder? I know the system uses pressure (mechanical assisted by vacuum) but won't gravity cause the fluid to drain the moment I "loosen" the fittings? Sorry to sound like an idiot here, but I figure it's better to ask and learn, than pretend to have the knowledge/experience and make a messy mistake.
Depending on my success with this install, and the install of my Hawk Pads & Powerslot Rotors, I may have a few more questions re: bench bleeding the master cylinder etc.
Thanks in advance for all the knowledge and experience you guys take the time to share on this site. It's awesome and I've learned a ton.
