Thanks for the welcome.
Basically you just take the motor off,and run the lines OUT from master cylinder to the corresponding IN line on the combo valve.
IIRC,one line is larger than the other so you can't mix them up.
Then you cut the original line from the pass front and put it into a T fitting with the driver front going in the other side.
The rear line goes into corresponding output on combo valve.
The remaining line from the T goes to corresponding output on combo valve.
Doesn't even throw an ABS light on my 92,haven't drove the 97 since I did it to it but imagine it will have a light.
The ABS light on the 92 IIRC is flagged from the combo valve anyway so if it's all good then no issues I guess.
Been awhile since I did this,so I might need to go take a look and make sure that's all it was.
But the 92 drives perfectly fine,brakes great and lockup isn't uneven.
I'll try to remember to pop the hood and make sure that's all it was.
If noone remembers the specs and facts on the ABS diag info and how the light flags i'll look it up if needed,I remember it was a very simple system though.
Honestly i'm a Ford tech,but GM trucks are my hobby. I have all this info laying somewhere,but haven't spent any time on my projects in months due to different issues.
times coming really soon though,and i foresee a flurry of activity and lots of free summit crap in my personal shop.
I work at Autozone part time some evening's so i've gotten to use that little Actron scanner,it's not too bad considering you can view freeze frame data.
I use a couple different laptop based scanners,they're great for viewing pids and graphing. Just looking at pids can allow you to start ruling things out in diagnosis.
