So, just wanted to check with forum members before I go get the battery tested but here is my issue: Tahoe starts up fine every morning but twice now I have run the battery down in a parking lot by using the liftgate a few times between startups. This seemed somewhat odd unless the liftgate is just using up too much cranking amps on a failing battery?
Also, the two separate times of running the battery down are about 4 months apart. Other than that, the battery never hesitates on startup.
Thoughts?
Thoughts?
