ppv horn not working
mr tahoe
Hey guys i have an 2008 ppv and im convirting the car to lt i have everything but im facing one problem wich is the horn its not working fuse is ok im getting negative power from the horn the car had lots of wires when i first got it when i was driving back from the lot while driving the horn would go on and off i guess some wires making contact so i know the horn itself is working but im not getting power to the horn if anybody knows a solution id be thankful
CptJumbo
it's probably where they cut the wires to install a hands free siren. Check your wires for continuity....When we install them we typically cut the wires so that it blows the airhorn instead of the stock horn.
mr tahoe
Hey guys thanks for the replays well i checked the fuse and its good and i hooked a wire from the battery to the horn fuse and it worked just fine i found 2 wires coming from under the dash that were disconnected,when these 2 wires make contact the horn will blow but pressing the horn or using the panic button nothing happens i checked the horn airbag on another car and it worked, im sure its a wire somewhere from steering till the fuse box, thanks again for the replays,
