I've tried googling for the answers, but what I found was both confusing and conflicting...
For the years I'm looking at, 2007-2011, what really do you get with a Z71 package that you can't get as options on other models? Can I simply buy a Tahoe with G80 locker, add skid plates, then swap out the springs/shocks and be non-cosmetically identical to a Z71 or are there other things like TC or axle gearing that are also different? I've seen things that hinted at differences in the bumper and fender flares, if true is this just cosmetic or is there a difference in approach angle or tire clearance?
With emphasis on off roading, is there anything else I should be aware of? Year to year changes, options that I'd want to make sure I get or that should be avoided?
