PLEASE HELP!!! New headlights, having blinker issues.
Mayday007
Hello Everyone,
I have a 2007 Chevy Tahoe z71. I replaced the stock headlights with a pair of Spyder HALO headlights. I did the wiring myself, re-connected the harness and here is what is happening. On the driver side ALL of the lights work perfectly. Headlights, high beams, and blinker light is functioning perfectly.
However, on the driver side, all of the lights are working perfectly but when I turn on the right turn signal light the light does not work AND the blinker light inside the vehicle blinks at a faster rate than normal. I have already put in a new turn signal bulb so that is NOT the issue.
Does anyone have any insight as to why the driver side and passenger side were wired exactly the same way but the turn signal on the passenger side is failing to light up and has a rapid blink rate inside on the dash?
Any suggestions would be greatly appreciated, thanks!!!
Mayday007
There is a row of LED lights along the bottom and halo lights but not sure if the bulb inside the halo is an LED light or not. My best guess is that they are not. The turn signal bulb is for sure not an LED as I have already changed it once.
The weird thing is that if I unplug the wiring harness so that nothing is connected to the passenger side and turn on the turn signal the blinker still blinks rapidly.
Any advice? Thanks!
