Ok so I will start by letting you know that we replaced our fuel pump about 2+ months ago and the shop said we needed a fuel line repair kit as well and so we had them do that too.... well the other morning (2 days ago) I went to start the truck after it had been parked over night and it was perfectly fine that night and I only drove it like 3 miles tops home from work with no incidents... well it wouldnt start, I got out and noticed that there was wet stuff all over the ground, it would crank over but wasn't catching... well the fluid on the ground was gas.... turns out there is some kind of seal that goes from the fuel line to the tank/pump and it is held in place by a little clip with a little spring system... and this part broke so the seal is not in place and so when you crank the truck it spits gas all over the ground and the engine doesn't get any... well yesterday GM said that we could order the part and seemed to know what we were talking about but then today apparently this part doesn't exist and in GM's system there is supposed to be a completely different fuel system period... which doesnt make any sense because everything is stock factory parts, or replacements from the dealer.... so now we need some part that if you get under the truck and look at it you can see but according to the rest of the world it doesn't exist,, anybody have any clue how to get around it or where I may be able to find a part like this? or even a name.. I am so frustrated with this whole thing! shouldn't GM know what parts their vehicles come with ! Thanks for any help I need it
