Please Help! Front and Rear camera
bearcatjoe
I posted once before but got no response. I'm still trying to figure this out. Ive had the lock pick installed for about 6 months, i had it controlling the factory rearview camera and everything worked fine. I just bought an aftermarket front camera and can not get them to work together. When I first hooked it up. The 2 images would overlap when in reverse and half the time in drive. I read where you need to install a relay and this is where the trouble is coming in...when i installed the relay i only got the front camera whether in forward or reverse.
any ideas? How do you wire the relay? i bought a 5 prong will only a 4 prong work? please provide any info possible that might help wire this relay correctly.
Nnaboy
Texas
Probably gonna have troubles finding help on this one because its not a commom mod.
Good luck though
SubZ3r0
it sounds like you have a wiring issue. might have hooked too many things up to the lockpick adapter...or something im not sure.. if i were you. have the backup camera hooked up as usual and if that works....thats fine.. then hookup the front camera to an aux RCA video imput if your headunit and manually switch to it.
unless the lockpick kit is supposed to decipher between the 2 that might be a failsafe way. because when your backing up. your not usually looking in front of you lol..........USUALLY!
