Pics of my '08 Suburban
bad63lac
New Jersey
Finally took some pics. I've had the truck for 5 weeks now.
Mods:
-Tinted front windows
-Satin Black on everything that was chrome (outer grill, emblems, lettering)
-Glossy Black grill mesh
-22x9.5" KMC Monster's, +35MM offset
-305/45R22 Toyo Open Country A/T's
More to come... :D
DofD
Victoria, BC
Nice job blacking it all out. :)
My suggestion would be to at least remove the flex fuel badge.
Gambler
Baltimore
I like everything a lot...with the possible exception of the valve caps...
Nnaboy
Texas
Looks good bro, black on these cars is the best!
bad63lac
New Jersey
Thanks... haven't had the chance to remove the Flex Fuel badge yet but I've been planning on it.
LTZBluez
Thats one SIK murdered out ride! :thumbsup:
fco_gonzo
I noticed your LE plates. I have a great amount of respect for FF, LEO, Military. Bad ass ride too!
cbramsey
Wilmington, NC
I liked your ride a lot. I have to admit I did not care for the valve caps but to each their own.
Gambler
Baltimore
Did you have to do any trimming due to rubbing for those wheels/tires?
bad63lac
New Jersey
No trimming. It clears full turn by 2-3mm. Don't forget that wheel offset plays a part as well. Offset moves the wheel/tire in/out so this will affect how close to the fenders the tire is at full turn.
My wheels are 9.5" wide and +35mm offset. If they were less offset (like 30mm) that would push them outward which would cause them to rub at full turn.
The tires do rub in one condition. If I have the wheel turned about full turn and the suspension compresses suddenly, it will give it a quick little rub. An example is if you are turning into a driveway where you're going up an incline and pull in a little faster than you should. If you come in slow it's fine but if you "cowboy" it in, you'll make the suspension compress and the tire will touch the fender a slight bit due to the angle.
scotto2323
TR, NJ
SICK!!! Might have to steal your rims:D
I like it debaged myself...but it has a unique look with the black emblems.
No it is time for a SS Hitch Cover and some chrome signal bulbs.
Are you planning on blacking out the tailights or headlights? Nightshade stock or aftermarket?
