sookeyukon
One of those weeks :mad2:
I took my 2001 Yukon in for a rebuilt EBCM due to an ABS problem. The work was completed however the shop can't seem to re-start the vehicle. Yes..it thinks it has been stolen. It's quite understandable to me that due to the battery being disconnected for a length of time and that the EBCM was removed from the Class 2 serial data circuit the "security" system has prevented a re-start shuting down the fuel injector/log.
The real problem is that my passlock ll (if that's what I have) will not re-learn the code after the many correct trys. The shop states he is not getting any DTCs in the system....and that the "security" light is NOT flashing while re-learning. Apperently..the passkey lll dosen't flash (just stays lite for 10 min)
THIS IS WHERE I NEED YOUR HELP.
I've been all over the web and found this "attachment" viewing GMs keys. My key is the one on the bottom right which states it's a PASSKEY lll! Passkey lll has a tad bit of a differance in the re-learn steps to get the code re-programed for correct re-start. Can anyone confirm there 2001 key (if it looks like mine). BTW, a lot of the GM information is a tad bit confusing! IE..They state that Passkey lll started in 97 and was widely used by 2000, however it also states that passlock started in 95 and was standard on 98 and up trucks and SUVs. To ID the key system it also says that if I have a "SECURITY" light, then it's a passlock system..Somethings wrong somewhere!
So please..does your 2001 yukon key look like mine? OR...could the attachment be wrong and the bottom right key should say passlock ll, NOT Passkey lll
Thanks guys/gals
Thanks guys/gals
