Paintless dent repair?
07 LT
Southern NJ
Hi..just wondering if anyone had a dent repaired using this method. I have 2 small dings in my hood in the front vertical part of the hood. There is some reinforcing sheet metal that may prohibit it from being accessed. :confused2:
thanks
TN Tahoe
Bartlett, TN.
thanks
Yes, I use a company here in Memphis, TN. called Dents-Away I have used them for small door dings and dents since the early 90s with great success. If the dent doesn't have a sharp edge or hard crease in the panel it will look as good as new. Funny you should post this question now. Graystone Ghost that is on this forum is a good friend and he just took his Tahoe in for service at the dealer by his home in Heber Springs AR. When they shut the hood they put a dent about the size of your thumb in it. He came for a visit here at our house and we took his Tahoe into Dents-Away.. Looked like new and just had the Tahoe for about 3 hours at their shop. Hope this helps. I would look in your area for someone that does this type work and look at some of the repairs they have done. :thumbsup:
07 LT
Southern NJ
Thanks TN- Going to look into it but I have read that the front of the hood is hard to access from behind, of course thats were the dings are. We'll see.
73shark
KC, MO area
I had a ton of hail damage removed from two SUVs that set out and after two years there was still no sign of the previous damage.
Dr. Overkill
El Cajon, CA
I've had 3 or 4 dents removed this way, and they didn't need to access the backside of the panel. Pretty impressive--lots of tapping around the dent with these little pegs, for lack of a better description. It's just this side of voodoo...
And small dings typically take only about 20-30 minutes.
_dennis
