My 2001 Tahoe has just recently started only blowing out hot air. The fan variable switch is working fine. The mod switch is working fine also. It is the temperature switch that no matter if it is on hot, cold, or anywhere in between I only get hot air. The rear controls are the same way. The A/C system isn't working at this time do to a leak in the system, which has been that way for a little while now, but I should still be able to get cool air by turning the temperature switch to cold. Has anyone else had this problem?
