cjadams350
- Jul 26, 2012
1999 tahoe 5.7 vortec
ok so i had a problem with my right rear tailight going out, it would make the front headlights blink fast. So i changed bulbes...didnt work, changed taillight circuit board.... Didnt work. So i installed a new turn signal switch and all the panels installed and plug battery in and horn was on. So i took everything back apart and i found that there is a small brown little push-in button on the turn signal switch that touches a metal part on the steering wheel and causes horn to blow. Do i have a bad ground some where? If so where do i check? Need help asap
