New owner Autoride and Airbag Light Questions!
aguita
Hello,
I own a 2010 tahoe ltz and i have a question about the autoride system.
Every time i turn the car on the compressor kicks in for some seconds then it shuts off, if i turn off the car and restart lets say 5 mins after the compressor kicks again and shuts down after some seconds. Is this normal to everytime i turn the truck on the compressor kicks?
Also when i pull my boat i can hear the compressor turning on lets say every 10 mins and shuts down after some seconds, does this sounds normal?
Couple of times i have been getting a intermittent airbag light along with service airbag system but i turn the car off and restart and the light won't come again, this have happened 3 times, what should I check?
thanks
xxChevyxx
I had an older Tahoe with Auto Ride that I had replaced 2 compressor pumps on. It was normal for the pump to run a lot, especially when towing. The shocks may have had a small leak in them to cause the pump to run a lot. My new Tahoe doesn't run a lot at all. It should run to fill up the shocks then shut off. If it is running a lot during driving, you should get it looked at or you will burn out your pump.
