adam74
have a couple questions. just bought a truck that I have wanted for some time now. 95 4x4 2 door w/body lift.
first thing is it was running descent right after I had changed the cap/rotor/plugs but now seems to stumble/hesitate at lower rpm when taking off, seems to clear out but just doesnt seem to have as much power. I did a basic tune up on it including fuel filter because it seemed to be running a lil rich based on the exhaust smell. It ran better after that, I did have to reset the timing because the cap was a pain to get off due to a screw stripping out. I did disconnect the timing wire under the dash to set it and then hooked it back up afterwards. no ses codes are stored, checked with a paperclip in the obd1 connector. have heard the egr valve would be a primary suspect but not positive, also it has what I would best describe as a lope once the rpms drop down to normal idle. I still plan on replacing the plug wires because they are the cheap skinny ones just havent gotten to it yet.
one other thing that I believe I already know the answer to but just checking on is the abs light is on. I took the sensors out to look/clean them and the passenger side one looks like it has been rubbing on something. I would assume the bearing assembly is out causing a rub on the tip of the sensor from my research I have already done.
