New Lower Control Arms
SClark44
Having a real hard time finding new lower control arms for my 1999 4WD Tahoe. I can find RWD ones just about anywhere. Are they the same?
I was going to replace the lower ball joints and put in new bushings on the old ones, but hell if I'm going to do all that work I'd like to use all new stuff. The old ones are badly rusted, specially since I live in the salt belt. A point in the right direction would be greatly appreciated. Thanks.
LCA's should be different as RWD uses coil springs and the 4WD uses Torsion Bars that socket into the LCA's..... Check out: RockAuto.com Amazon.com LMCTRUCK.com (add www. to the beginning.....)
Slammed
CT
You might not find them i just did my uppers $400 each! And the lowers no where to be found so i did the bushings
