Hmmm....... Security light at first is in bulb test (with the other lights)
Try This
10 Minute Learn Procedure
•Starting from the off position.
•Attempt to start the engine, then release the key to Run position (vehicle will not start).
•Observe the security light located in the instrument cluster, after approximately 10 minutes the security light will turn OFF. Turn OFF the ignition, and wait 5 seconds.
•The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
Important
The vehicle learns the Passlock Sensor Data Code and/or resistance on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
However if the column you used is a 97 and passlock 1 not 2 this may not work.
As 1998 is passlock 2.
Ed
(FROM FSC.COM)
This is the relearn procedure, there is a 30 minute one that may need to be done.....
I tried this learn process again today. It did not work.
My security light turns off after about 3-4 seconds.
Important
Performed as instructed, ensuring switch was off, and waited 5 seconds, before cranking. Same result: engine starts initially, but shuts off immediately.
I did notice that on my replacement ignition cylinder I am able to turn the key back toward me (passed the off position) to be able to listen to the radio, ect. And on the ignition cylinder I am trying to replace, this cannot be done.
I'm dying to replace the ignition cylinder because with the current one, the key has to be placed in the ignition just right, at an awkward angle for it to work and turn the cylinder which is a real pain. Also, I've swapped all of the handles and locks from my old Tahoe already, since the ones that came with this Yukon were painted and all busted up.
