My first tahoe purchase 1997 2 door
Jaredboy23
Need some help before i make a purchase. Im just trying to figure out what parts may be interchangeable with the 97 2dr tahoe as it will need a lot of new interior pieces.
What year parts would work?
For instance if i wanted to update all of the seats and door panels to leather and matching what years could i play with?
Thanks in advance.
1995-2000 for interior pieces, engine is 96-00....
Ice98
Generally most parts from 95-99 are interchangeable, obviously if it is a Tahoe there are certain parts for the rear half that will not fit if they are out of a suburban due to the longer nature of the suburban, but most other parts will work
This includes silverados, and the GMC equivalents, they are all very similar at the base
For interior parts on a 97, you would have to use 97-99 parts, as I believe the dash was changed between 95 and 96 as was the steering column, not sure if the older models had power seats and whatnot, but any seats/etc out of a 96-99 should bolt right in
Forgot about the dash on 97+, but the advent of the passenger side airbag in 97 does make that side of the dash different, the drivers side is same.
Also trucks are 1995-1999CLASSIC as in 99 there was Classic (ours) and the NewBodyStyle (NBS)...
