replacing the bulbs with LEDs disables the cruise control, I have read on where other people had to use resisters in conjunction to the leds.
Most of the newer LED taillights have load equalizers built in to prevent this. A quick test for this would be to simply turn on your turn signals (left or right). If the dash indicator flashes fast like when a bulb is burnt out, then then the tail light needs a load equalizer.
Tast101:
I have your tail lights without any problems. Your load equalizer is that little black box in the middle of your tailight when looking at it from the inside.
Your brake lights start wtith a 25 amp fuse in the engine compartment, then the left and right tail light split off from the third tail light in the driver fuse panel. Since your third brake light is working, then your underhood fuse is working. Double check your vehicle stop tail lamp fuse. It is in the driver fuse panel, lower left, and it is a 15A fuse. Even if it tests good, change it out anyways just to make sure.
Also, are you sure you plugged in the LED's correctly? I am not trying to be a smartass, but those plugs have the ability to go in either way, BUT there is a correct way to plug them in. The two black wires (ground) on the LED plug have to match the black wire (ground) on the car's socket. This may be easy to overlook. Do your tail lights light up at all when you turn on your parking lights? If they do, then you at least have them plugged in correctly.
Lastly, gumby gives good advice when suggesting that you also try your stock tail lamps again. Maybe your LED's gave out? (I doubt this happened)
Good luck!
