mirror question
Ont240
I have an 07 Tahoe LT with the factory power mirrors.
Does anyone know if the OE power plug to the mirror has additional contacts/wires for heat, turn signal or other?
Looking at Ksource tow mirrors, for an 8' wide trailer that have the added functions.
Thanks for your input
crosby790
Power, Heat and turn signal are plug and play! Everything is already there! If you want power folding, heat, turn signal, exit lighting (for water puddles) you will need to replace both door switches also and have switches programmed or install used switches with the option already programmed. Also known as DL8 to DL3 mirror upgrade.
Sent from my SM-P900 using Tapatalk
khelm43
Help adding power fold mirrors to 2009 suburban
I recently purchased a 2009 suburban LT with 37,000 miles on it. It had nearly everything I was looking for on it but I want to add power folding mirrors as it doesn't have them. I see that I will have to replace the mirrors and probably can reuse my body colored housing trim and that I will have to add switches that will need programed. Can anyone help me with this as far as where to go to purchase what I need at the best price. Also the mirrors I have do not have the turn signal indicator in the mirrors, that would be nice to add but the power folding feature is what I need most. Thanks. Kevin
crosby790
I haven't seen any power fold that did not have the signal indicator. You can use your housing trim but you will need to take a dremil tool and cut out for the additional switch (this is what I did) for the power fold option. I'm very happy with my upgrade although I lost courtesy lamp operation when I open the front doors only ( still works with remote, rear doors and dash switch). I could probably go to the dealer and get courtesy lamp programmed back in.
