MagnaFlow Direct-Fit Catalytic Converters by Car Sound
clkelley
Moderator
Galax, Virginia
Magnaflow Direct Fit High Flow Catalytic Converter
attachment.php
Part Number: M/F93419
Body Material: Stainless Steel
Heat Shield: Stainless Steel
Inlet Size: Flange
Outlet Size: Flange
Length: 12in.
O2 Bung: Yes
Air Inlet Port: No
Carb Approved: No
EPA Approved: Yes
OBD II Approved: Yes
Fitment: Direct Fit
Mounting Flange: Yes
Offset Inlet Or Outlet: No
MagnaFlow Direct-Fit Catalytic Converters by Car Sound are designed for easy bolt-on installation for the Professional Installer. Each is designed to exact the original equipment specifications. While the majority of the Direct-Fit Catalytic Converter products do not require welding, cutting or bending, limited applications may require additional welding for optimal installation.
CLICK HERE TO Place Your Order TODAY!
Please Include Year/Make/Model/2X or 4X/Engine Size/2dr or 4dr
