MyBlkBurban
Thanks to 05Z71BURB from z71tahoe-suburban.com for inspiring me with "Poor Mans In-dash Navigation 1st Lame Mod" and my attempt ...
Updated Pic's
I picked up a switch and auxilliary power socket at radioshack, along with a blade fuse tap in and had a little fun. My intent was to install this and make it as close to "non permanent" as possible and not drill any unnecessary holes.
- I removed the dash and pocket
- Installed a couple of layers of adhesive insulation tape and built up the space between the dash and the pocket void ( roughly 1.5" )
- Tapped the fuse blade into the 10amp SEO ACCY fuse on the drivers side and ran a wire under the dash into the center console where it becomes an on and off switch.
- Removed the cig lighter ( since I don't smoke - bun in retrospect I probably would have probably swapped the cig lighter to the spot where the aux power outlet is and then kept the cig lighter option - but i accidentally broke the cig lighter on removal so - too late for that - Unless someone has an extra cig lighter they want to send me
- Used the spot where the cig lighter was to install the switch. The switch was a tad too small for the hole - so I just reused the black trim piece from the old cig lighter and then used a small c clamp to hold the switch in perfectly...
- Ran another ground wire to the passenger side panel that had a nice grounding nut.
- Put the new aux power outlet behind the glove compartment and plugged the Magellan unit right into it.
Now all I do is flip the switch and GPS goes on and flip it off and the unit shuts off... I love the look and GPS signal is 100%. No degradation that I have seen so far.
* I used an aux power outlet so that if I want to remove the unit - all I do is unplug it and replace it - no need for splicing wires ....
Things I would have done differently:
As I mentioned before, I would have not gotten rid of the Cig lighter and instead swapped positions with the aux power right next to it on the console and then reused the aux power from the console as the power source for the GPS -- thus saving me a cig lighter and $7 buck additional outlet from radio shack
Updated Pic's
