My Low pressure warning light recently came on however, there is plenty of tire pressure... LED says 19 - 20 lbs, but have over 30lbs. Is the sensor bad? If so is it hard to replace or reset?
Most likely the sensor is bad. Any tire shop should be able to replace it. Make sure your tires are within 6 psi from each other. (from recommended pressure)
