96 2dr Yukon keeps burning up fuel pump relays. Anyone experienced this? The truck runs fine for a while then will suddenlly either die out while driving or not start. Inevitably I go to the relay and it is either semi melted on one of the terminals (same one every time) or has a poor connection. Now the connection on the fuse box is slightly melted and causes a worse connection problem.
Is my fuel pump going bad and causing this or do I have a different problem? This has been an ongoing issue for the past couple years. :zav:
Thanks
Thanks
