JD Larue
So I was under the hood today checking the oil, tranny, etc. and I noticed my radiator fluid was a little low. When I went to unscrew the cap I noticed that the whole reservoir seems to be loose and moves around if you take hold of it and wiggle it. Not up and down so much but mostly back and forth movement. I checked all the bolts holding it to the fender well and they are all tight.
Does anyone else have this issue (and is this normal) or do I need to look into it a little further?
Thanks
Thanks
