DISCLAIMER: This is my first post here so please excuse the length and/or ignorance that follows.
I am kinda long winded but will try to keep it short in the future. For now though, here it goes.
Well after years and years of longing to own a 2DR I finally found the one. It's a red '95 Z71 with 211,XXX miles. I have looked long and hard for a deal like this and finally found it. Every one of these things I have found was either way overpriced or just not well taken care of. This one was priced well below what I have looked at in the past and is in better condition, inside and out, than 95% of the ones I had previously looked at. It has power windows/locks/mirrors and everything works. There are(were
) some very minor things that needed some attention but were fixed very easily. One was that the A/C control panel did not illuminate when the lights were turned on. Pulled the dash and found that there are 4 bulbs behind the panel and they were all bad! 5 minutes and that was fixed. The A/C did not blow cold so I pulled a vacuum on the system and put one can of freon in it and found the front seal was leaking. Bought a reman compressor from Napa and installed it after work before I went home on Friday night. After I got everything back together and pulled a vacuum on the system for about 30 minutes and charged it up. As soon as I hit the A/C button it let out a squeal. It was locked up! And before anyone asks, yes I put oil in it. The thing didn't make one revolution. So Saturday I had to go warranty it out and do it all over again. It was much easier the second time around.LOL
Now for the few (and hopefully minor) issues that I have to fix. It has a very small engine oil leak that appears to be coming from the oil filter header. Also the transfer case seems to have a small leak as well. The engine oil leak is so minor that it has yet to put a drop in the driveway but it is leaking ever so slightly because it always has a fresh drop or two just waiting to fall. The transfer case however, leaves several drops every night. It is dripping from the skid plate but it appears to be leaking on the right side where the two cases come together. I tried to pressure wash the entire undercarriage the other day but it's nearly impossible to get up under there to every nook and cranny that the oil and dirt seem to have no problem finding. Also the driveline has a "clunk" more than likely fixable by greasing the transfer case output shaft(Yeah I am new here but I do know forum etiquette. I did my search.) and replacing the u-joints. My last concern is that I rarely haul my boat, and only owning this truck for a week, I went to pull it out of the water for the winter and the truck would not pull the thing up the ramp. For some reason it would not rev over 1800 RPM's. I had to put it in 4WD to pull it out. Once on level ground it pulled just fine. The boat and trailer weight about 5,000# but the truck should be able to pull that up a ramp with no issue at all. Later on I tried to power brake to see if it would do the same thing and it did. The engine would not go over 1800 RPM's. It's not like the trans is slipping because the engine would have to actually rev up for that to happen so I'm at a loss as to what the problem is. Any help would be greatly appreciated. Thanx and sorry for the long post. It's my first so I figured I'd do it right. Sorry.
