goldenrod49
- Nov 23, 2007
***Not sure where to post so did two***
Has anyone else had this problem? The GMX-320 install went fine and works as it should but the factory back up camera has no video feed. When I put the hoe in reverse I DO get the screen switching over to rear camera and the message across the top in yellow is also there but no actual image. I have a 2008 Tahoe LTZ with all factory Nav, Rear DVD and Camera. Dip switch 1 and 2 are down, 3,4 and 5 up. I did NOT do the splice step to turn on the camera anytime and no other video/aux sources on the lock pick are being used. For my application should all of the harness's have been used?
Any info will be greatly appreciated! I plan on opening it up again on Tuesday if anyone has any thoughts.
