On Dec 31st, I purchased a 2007 Tahoe LT w/ lots of options.
Re the power liftgate, I believe the liftglass opens separately from the entire rear hatch? However, using the rear liftgate soft-key/open button, nothing happens or can be heard to release the liftglass. Same w/ the remote. Both remote and rear handle soft-key will open the liftgate. Looking closer, I am beginning to wonder if the liftglass really opens separately with the power liftgate option. Any answers?
Also, the REPLACE BATTERY IN REMOTE KEY message was on when purchased. I wrongly figured this to be an easy fix. Replaced both key fob batteries, but the message continues to display. After battery change, the Chevy dealer tested output of both fobs to test-box satisfactorily. However, only one remote worked with the vehicle. Went through the RELEARN REMOTE KEY option using the primary key fob. All functions worked, but still had the message. Later, found the secondary key fob did nothing; no lock, unlock, etc.. Tried the RELEARN REMOTE KEY option with secondary fob, but no success. So two question; one, how do I clear the REPLACE BATTERY IN REMOTE KEY message, and two, how do I get the second key fob to communicate with the vehicle again?
Thanks, Dave
Thanks, Dave
